Date/Time: Wed, 27 Nov 2024 11:49:10 +0000
commission on simulated feed
View Count: 261
[2023-08-25 15:32:26] |
User61576 - Posts: 444 |
I have set the commission for both global round turn and per symbol in the symbol settings and also in the setup of the simulated trading account and yet the commission is not being charged on the trade activity log pls check the attached screenshots would be happy if you could tell me what else I need to check/set thanks |
Screenshot_13.jpg / V - Attached On 2023-08-25 15:28:49 UTC - Size: 119.05 KB - 77 views Screenshot_12.jpg / V - Attached On 2023-08-25 15:28:54 UTC - Size: 417.65 KB - 67 views Screenshot_14.jpg / V - Attached On 2023-08-25 15:31:26 UTC - Size: 469.53 KB - 65 views |
[2023-08-25 15:40:28] |
John - SC Support - Posts: 36309 |
On the Trade Activity Log in the section at the top with the filters, is a box for "Use Commission". This needs to be checked for the commission to be added. Refer to the following: Trade Activity Log: Use Commission For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
