Date/Time: Wed, 27 Nov 2024 11:45:02 +0000
Questions on software
View Count: 282
[2023-08-24 19:28:52] |
User165981 - Posts: 1 |
I want to see if your software can do what I'm looking for. I want to do daily RTH charts with the ability to see the OHLC of the day as well as the opening range. I have rithmic data already. This will only be used for charting. Can you software do this? I tried the demo but I don't see these options to check this out. |
[2023-08-24 21:21:48] |
John - SC Support - Posts: 36309 |
Yes, the software can do this. To limit the times on the chart, you need to set the Session Times as you want them. Refer to the following: Chart Session Times For the OHLC, use the "Daily OHLC" study. Refer to the following: Daily OHLC In order to get the Opening Range, you would use the "High/Low for Time Period - Extended". Refer to the following: High/Low for Time Period - Extended For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
