Date/Time: Wed, 27 Nov 2024 10:47:02 +0000
No live data
View Count: 265
[2023-08-24 13:59:09]
User213504 - Posts: 69
I have Sierra V. 2540 and subscribed to Teton but I'm not getting any live data. If I delete and download the data the charts are updated. I have filed a support ticket but no reply.
Ron
[2023-08-24 14:04:46]
Sierra_Chart Engineering - Posts: 17191
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-08-24 14:11:56]
Software version: 2540 64-bit | 2023-08-24 14:07:40.700
Primary Thread ID: 3964 | 2023-08-24 14:07:40.700
Usage end date: 2023-11-07 | 2023-08-24 14:07:40.700
Enabled for: Sierra Chart Historical Data Service. | 2023-08-24 14:07:40.700
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-08-24 14:07:40.700
Enabled for: Delayed Denali Exchange Data Feed. | 2023-08-24 14:07:40.700
Enabled for exchange2: CME | 2023-08-24 14:07:40.700
Enabled for exchange2: fairx_exchange.data | 2023-08-24 14:07:40.700
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-08-24 14:07:40.700
Current selected Data/Trading service: Teton CME Order Routing | 2023-08-24 14:07:40.700
Custom symbol settings values: enabled | 2023-08-24 14:07:40.700
Chart Update Interval: 500 | 2023-08-24 14:07:40.700
Intraday Data Storage Time Unit: 1 | 2023-08-24 14:07:40.700
Time Zone: +00:00:00 (UTC+00) | 2023-08-24 14:07:40.700
2023-08-24 14:07:40 Local computer time in UTC | 2023-08-24 14:07:40.700
2023-08-24 14:07:40 Local computer time in SC Time Zone | 2023-08-24 14:07:40.700
2023-08-24 13:45:51 Server time in UTC | 2023-08-24 14:07:40.700
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-08-24 14:07:40.700
Program path: C:\SierraChart\ | 2023-08-24 14:07:40.700
Data Files path: C:\SierraChart\Data\ | 2023-08-24 14:07:40.700
OS Version Number: 10.0 | 2023-08-24 14:07:40.700
Locale Setting: C | 2023-08-24 14:07:40.700
DLLs: UserContributedStudies_64.dll | 2023-08-24 14:07:40.701
Allowed protected custom studies: EMiniPlayer | 2023-08-24 14:07:40.701
Crash reporter started: true | 2023-08-24 14:07:40.701
Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048 | 2023-08-24 14:07:57.747
DTC Client socket (3) | Creating socket. | 2023-08-24 14:07:57.749
DTC Client socket (3) | New receive buffer size: 0 | 2023-08-24 14:07:57.749
DTC Client socket (3) | Connecting to IP: 142.215.17.189. | 2023-08-24 14:07:57.749
Denali Data Feed | Network connection to server complete. | 2023-08-24 14:07:57.782
Denali Data Feed | Starting socket receive thread. | 2023-08-24 14:07:57.782
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-24 14:07:57.782
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-24 14:07:57.822
Denali Data Feed | Sending logon request message. | 2023-08-24 14:07:57.822
Denali Data Feed | Received logon response. | 2023-08-24 14:07:59.587
Denali Data Feed | Server Name: RealTime Server. | 2023-08-24 14:07:59.587
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-24 14:07:59.587
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-24 14:07:59.587
Denali Data Feed | Failed connections: 49 | 2023-08-24 14:07:59.587
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-24 14:07:59.587
DTC Client socket (3) | CloseSocket call. | 2023-08-24 14:07:59.587
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-08-24 14:07:59.587
Denali Data Feed | Disconnected from the server. | 2023-08-24 14:07:59.587
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-24 14:07:59.587
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-08-24 14:07:59.643
DTC Client socket (3) | Closed. | 2023-08-24 14:07:59.643
Saved Chartbook: Micro ES.cht. Time: 0.0274 seconds. | 2023-08-24 14:08:12.686
Unsubscribed from market depth data for MESU23_FUT_CME | 2023-08-24 14:08:17.540
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 | 2023-08-24 14:08:29.599
DTC Client socket (3) | Creating socket. | 2023-08-24 14:08:29.601
DTC Client socket (3) | New receive buffer size: 0 | 2023-08-24 14:08:29.601
DTC Client socket (3) | Connecting to IP: 142.215.18.148. | 2023-08-24 14:08:29.601
Denali Data Feed | Network connection to server complete. | 2023-08-24 14:08:29.634
Denali Data Feed | Starting socket receive thread. | 2023-08-24 14:08:29.634
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-24 14:08:29.634
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-24 14:08:29.675
Denali Data Feed | Sending logon request message. | 2023-08-24 14:08:29.675
Denali Data Feed | Received logon response. | 2023-08-24 14:08:32.380
Denali Data Feed | Server Name: RealTime Server. | 2023-08-24 14:08:32.380
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-24 14:08:32.380
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-24 14:08:32.380
Denali Data Feed | Failed connections: 50 | 2023-08-24 14:08:32.380
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-24 14:08:32.380
DTC Client socket (3) | CloseSocket call. | 2023-08-24 14:08:32.380
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-08-24 14:08:32.380
Denali Data Feed | Disconnected from the server. | 2023-08-24 14:08:32.380
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-24 14:08:32.380
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-08-24 14:08:32.411
DTC Client socket (3) | Closed. | 2023-08-24 14:08:32.411
MESU23_FUT_CME 1 Min #1 | Reloading chart. | 2023-08-24 14:08:53.782
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-08-24 14:09:02.378
DTC Client socket (3) | Creating socket. | 2023-08-24 14:09:02.378
DTC Client socket (3) | New receive buffer size: 0 | 2023-08-24 14:09:02.378
DTC Client socket (3) | Connecting to IP: 142.215.18.148. | 2023-08-24 14:09:02.378
Denali Data Feed | Network connection to server complete. | 2023-08-24 14:09:02.412
Denali Data Feed | Starting socket receive thread. | 2023-08-24 14:09:02.412
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-24 14:09:02.412
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-24 14:09:02.477
Denali Data Feed | Sending logon request message. | 2023-08-24 14:09:02.477
Denali Data Feed | Received logon response. | 2023-08-24 14:09:04.275
Denali Data Feed | Server Name: RealTime Server. | 2023-08-24 14:09:04.275
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-24 14:09:04.275
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-24 14:09:04.275
Denali Data Feed | Failed connections: 51 | 2023-08-24 14:09:04.275
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-24 14:09:04.275
DTC Client socket (3) | CloseSocket call. | 2023-08-24 14:09:04.275
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-08-24 14:09:04.275
Denali Data Feed | Disconnected from the server. | 2023-08-24 14:09:04.275
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-24 14:09:04.275
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-08-24 14:09:04.422
DTC Client socket (3) | Closed. | 2023-08-24 14:09:04.422
Denali Data Feed | Connecting to the server ds23.sierracharts.com. Port 10048 | 2023-08-24 14:09:34.292
DTC Client socket (3) | Creating socket. | 2023-08-24 14:09:34.295
DTC Client socket (3) | New receive buffer size: 0 | 2023-08-24 14:09:34.295
DTC Client socket (3) | Connecting to IP: 142.215.17.190. | 2023-08-24 14:09:34.295
Denali Data Feed | Network connection to server complete. | 2023-08-24 14:09:34.420
Denali Data Feed | Starting socket receive thread. | 2023-08-24 14:09:34.420
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-24 14:09:34.420
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-24 14:09:34.466
Denali Data Feed | Sending logon request message. | 2023-08-24 14:09:34.466
Denali Data Feed | Received logon response. | 2023-08-24 14:09:36.762
Denali Data Feed | Server Name: RealTime Server. | 2023-08-24 14:09:36.762
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-24 14:09:36.762
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-24 14:09:36.762
Denali Data Feed | Failed connections: 52 | 2023-08-24 14:09:36.762
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-24 14:09:36.762
DTC Client socket (3) | CloseSocket call. | 2023-08-24 14:09:36.762
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-08-24 14:09:36.762
Denali Data Feed | Disconnected from the server. | 2023-08-24 14:09:36.762
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-24 14:09:36.762
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-08-24 14:09:36.795
DTC Client socket (3) | Closed. | 2023-08-24 14:09:36.795
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 443 | 2023-08-24 14:10:06.758
DTC Client socket (3) | Creating socket. | 2023-08-24 14:10:06.761
DTC Client socket (3) | New receive buffer size: 0 | 2023-08-24 14:10:06.761
DTC Client socket (3) | Connecting to IP: 142.215.17.187. | 2023-08-24 14:10:06.761
Denali Data Feed | Network connection to server complete. | 2023-08-24 14:10:06.793
Denali Data Feed | Starting socket receive thread. | 2023-08-24 14:10:06.793
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-24 14:10:06.793
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-24 14:10:06.844
Denali Data Feed | Sending logon request message. | 2023-08-24 14:10:06.844
Denali Data Feed | Received logon response. | 2023-08-24 14:10:08.518
Denali Data Feed | Server Name: RealTime Server. | 2023-08-24 14:10:08.518
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-24 14:10:08.518
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-24 14:10:08.518
Denali Data Feed | Failed connections: 53 | 2023-08-24 14:10:08.518
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-24 14:10:08.518
DTC Client socket (3) | CloseSocket call. | 2023-08-24 14:10:08.519
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-08-24 14:10:08.519
Denali Data Feed | Disconnected from the server. | 2023-08-24 14:10:08.519
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-24 14:10:08.519
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-08-24 14:10:08.545
DTC Client socket (3) | Closed. | 2023-08-24 14:10:08.545
[2023-08-24 14:23:35]
This is the problem:
Refer to:
Denali Exchange Data Feed: Connections
Date Time Of Last Edit: 2023-08-24 14:23:44
[2023-08-24 14:34:57]
Thanks, I had it running on my laptop and forgot to shut it down before shutting the laptop off. Sorry to bother you.
