Date/Time: Wed, 27 Nov 2024 11:39:35 +0000
Setting up a 50EMA high and low close channel
View Count: 341
[2023-08-24 13:01:56]
User181655 - Posts: 61
How do you set up an Exponential moving average channel of say 50ema high and 50ema low on Sierra charts?
[2023-08-24 15:43:38]
Sierra_Chart Engineering - Posts: 17191
Add 2 Moving Average-Exponential studies each configured as required:
Chart Studies: Adding/Modifying Chart Studies
[2023-08-24 16:10:38]
It doesn't give you the option of 50ema high and 50ema low....which is what i want to create the EMA tunnel/channel ?
[2023-08-24 16:15:19]
John - SC Support - Posts: 36309
How are you defining the High and Low?
[2023-08-24 17:07:22]
It is I believe the 50 Period EMA of the Highs and the 50 Period EMA of the Lows
[2023-08-24 21:04:40]
Then as stated previously, you need two copies of the "Moving Average - Exponential" study, one set to a 50 period for the Highs and one set to a 50 period for the Lows.
If you want to color the channel in between the lines, then refer to the following:
Chart Studies: Filling the Area Between Two Study Subgraphs within Different Studies
[2023-08-25 12:24:59]
Thank You ...it's sorted
