Date/Time: Wed, 27 Nov 2024 00:45:43 +0000
Letter/Blocks In Own Columns - All Profiles Problem
View Count: 1182
[2014-07-13 13:50:49] |
bmoney - Posts: 32 |
Whenever I use "Letter/Blocks In Own Columns - All Profiles" some of my Letter/Blocks end up in the volume profile right next to it (I use TPO profile and a volume profile side by side). This problem never happens when I put the Letter/Block in own columns individually.
[2014-07-13 21:37:22] |
Attach an image showing what you are seeing. Here are the instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-15 09:56:05] |
We see a problem with how the "Letter/Blocks In Own Columns - All Profiles" function is implemented and we will correct it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-15 09:56:19
