Date/Time: Fri, 18 Oct 2024 04:07:09 +0000
[User Discussion] - Smart Money Concept Indicator
View Count: 1303
[2023-08-24 00:34:03] |
User810342 - Posts: 4 |
Is there a Smart Money Concept Indicator for SierraChart like the one below:
Screenshot 2023-08-23 193047.png / V - Attached On 2023-08-24 00:31:13 UTC - Size: 122.57 KB - 435 views Attachment Deleted. |
[2023-09-12 15:49:56] |
User658125 - Posts: 20 |
I would like to see this available as well.
[2023-09-12 17:03:59] |
John - SC Support - Posts: 35333 |
Take a look at the following Drawing Tools: - Price Retracement - Price Expansion - Price Projection Refer to the following: Chart Drawing Tools: Price Retracement (2 point) | Price Expansion (2 point) | Price Projection (3 point) Tools For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-15 14:40:27] |
Mohsin - Posts: 2 |
I am too interested in this tool. But the support's reply by John doesn't make any sense. Does anyone know how I can go about getting or coding this indicator?
[2023-09-15 14:53:38] |
User907968 - Posts: 821 |
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php |
[2023-09-23 23:28:31] |
Mohsin - Posts: 2 |
Thanks User907968, this helped a lot.
[2024-05-27 19:17:13] |
Moshin... Did you ever find anyone to create the SMC codes that you were seeking? |
[2024-06-21 09:55:35] |
User92573 - Posts: 525 |
Sierra ACSIL will allow extend until intercept and there are other examples of that could be adapted within the code for Imbalance.
