Date/Time: Wed, 27 Nov 2024 11:51:52 +0000
Using Value from one study as input to another.
View Count: 414
[2023-08-23 20:10:55]
Hofmeister - Posts: 27
Is it possible to use values like ADR or ATR in another study, like an input for a moving average or something?
[2023-08-23 21:18:18]
John - SC Support - Posts: 36309
Absolutely. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study
[2023-08-23 22:47:52]
Awesome, Thank you very much.
[2023-08-23 23:11:59]
Hmm, I don't think you can do one of the things I was trying to do. One thing I wanted to try was to take the ADR value, multiply it by 2 and use if in the volume by price study to draw my peaks and valley's. Do you know if this is possible?
[2023-08-24 03:47:51]
Sierra_Chart Engineering - Posts: 17191
No this is not possible.
[2023-08-24 15:36:41]
The Volume by Price study only works on the actual volume and can not have another input. It is one of the few that falls into this category, along with TPO and Numbers Bars.
But we are wondering if you were really wanting to create a Volume profile from the ADR information. If you give us some additional information we may be able to point you to a solution for what you are really wanting to do.
[2023-08-24 15:50:36]
Hi John,
Basically I was trying to setup "dynamic" peaks and valleys on the volume profile study. The idea was to as the ADR or volatility in the market went up or down it would adjust the peaks and valleys sensitivity giving you clues to hold onto a trade or close a trade.
[2023-08-24 16:14:02]
You would have to create a custom study to do this, as you can adjust the Input settings for another study from your study. Refer to the following:
sc.SetChartStudyInputInt()
