Date/Time: Mon, 25 Nov 2024 17:44:42 +0000
10 year
View Count: 494
[2023-08-23 19:56:14]
User143551 - Posts: 100
i need to put on my chart a cme 10 year treasury note what symbol do i use , i only can get tnu23 and its not the right one u need phones
[2023-08-23 21:17:39]
John - SC Support - Posts: 36254
TN is the "Ultra 10-Year U.S. T-Note" from the CBOT.
Also on the CBOT is ZN (10-Year Treasury Note) and 10Y (Micro 10-Year Yield Futures).
You can always use the Search feature in the "Find Symbol" page to look for this kind of item. Refer to the following:
File Menu: Searching for Symbols
[2023-08-23 23:39:20]
i can not get it ihave looked at all cbot , cme cant get any, 30 seconds on the phone would fix this
[2023-08-24 15:32:11]
What exactly is the problem you are having? Are you not able to find those symbols in your Find Symbol page?
Attached is an image of what your Find Symbol window should look like for the CBOT (our servers show that your Current Selected Service is the Teton Order Routing Service). We have highlighted the 10Y and you can see TN and further down (but not visible) is ZN.
imageFindSymbol-CBOT.png / V - Attached On 2023-08-24 15:32:09 UTC - Size: 78.59 KB - 99 views
[2024-02-21 14:45:16]
i need to fix my crosshair after downloadeing a update i cant fix it are you going to fix the updates to fix the promblem
[2024-02-21 17:16:34]
We assume you are referencing the text in the Price and Time boxes. There is a new setting for this in the Graphics Settings named "Chart Values: Price and Time Boxes Text Color"
