Date/Time: Sun, 20 Sep 2026 14:56:03 +0000
sc.Index increment at Ask/Bid event
View Count: 1294
| [2014-07-13 04:29:57] |
| User44130 - Posts: 23 |
sc.Index increment only when a trade occurs within corresponding time period. If a study is based on Ask/Bid events the results are lagging as they are shown against the last Index that might be minutes back because there is no current sc.Index. Is there a way to increment sc.Index when Ask/Bid event come? There's option in Graphics settings called Draw Zeroes but it works only visually, Index itself does not increase and remains at last trade event.
| [2014-07-13 05:03:48] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_RecordingModes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
