Date/Time: Wed, 27 Nov 2024 11:48:51 +0000
Volume profile indicators download into Sierra Spreadsheet
View Count: 289
[2023-08-23 09:57:14]
inapoli74 - Posts: 3
Hi there, as you can see from the SC chartbook attached I can't download the volume profile indicators into the spreadsheet studies. Can you please have a look at it and let me know if there is any bug?
Private File
[2023-08-23 18:35:52]
John - SC Support - Posts: 36309
This is correct - you can not get any information from the Volume by Price study into a Spreadsheet. The only option is on the Spreadsheet Inputs for "Output Volume by Price Data". Refer to the following:
Spreadsheet Study Inputs: Output Volume at Price Data
[2023-08-24 05:13:28]
Any other way to download the TPOC , TPOVAH, TPOVAL?
Many thanks
[2023-08-24 15:38:55]
Use the TPO Value Area Lines study on a separate chart (you can not use this on the same chart that has a TPO study on it). Then you can get that information into the Spreadsheet. Refer to the information here:
