Date/Time: Wed, 27 Nov 2024 10:36:44 +0000
How to interpret Max Send Buffers Used
View Count: 278
[2023-08-23 01:54:42] |
User987654 - Posts: 69 |
Hi, I have remote buffer delay send time set to 20ms. On the message log, I see: DTC client #14. 127.0.0.1 (2) | Max send buffers used during socket life: 10 | 2023-08-22 20:46:54.511 How do I interpret this? does this mean at its worst, the lag was around 200ms? Doesn't appear to be anything in documentation on Max Send Buffers Used. Thanks |
[2023-08-23 13:34:09] |
Sierra_Chart Engineering - Posts: 17191 |
We cannot help with this. It is complex to be analyzing this. Just ignore that number. However it does look to be high, that 10 buffers are being used on a local socket connection. If data is flowing, without interruption it would normally be one or two buffers used. We will not comment on this further. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-23 13:34:25
