Date/Time: Sat, 06 Jun 2026 14:29:05 +0000
Free Trial Activation
View Count: 2017
[2023-08-22 19:25:14]
Maneeharan Selvananthan - Posts: 1
Hi there, Could you please activate my free trial, if it is not activated by me earlier. I am not sure it is activated or not.
Thank you.
[2023-08-23 15:22:31]
Sierra_Chart Engineering - Posts: 23945
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
[2025-01-21 01:16:51]
User979224 - Posts: 3
[2025-01-21 18:06:24]
John - SC Support - Posts: 46532
User979224:
There is nothing to activate for the trial. You are currently on the trial with 22 days of Usage Time remaining.
Refer to the following for what data is available during a trial:
Sierra Chart Trial Account
And go through the items at the following link to get started with Sierra Chart:
Getting Started, Opening Charts and Basic Trading
