Date/Time: Mon, 16 Sep 2024 19:10:44 +0000
Importing CFD trades into SC
View Count: 265
[2023-08-22 10:17:34] |
amirN - Posts: 159 |
Hi, I trade CFD and use SC for charting. I can export my CFD trades but having problem importing them into SC (at the end of the day) to review (i.e. seeing my fills visually). I have tried to use the import function in trade activity log, although I do not get any error message the trades are not shown in the activity log and the chart. What are my options? Thanks |
[2023-08-22 15:31:26] |
John - SC Support - Posts: 34450 |
You would first need to export data in order to have the correct format the file. Then you can modify what is in that file and import the data from there. Refer to the instructions here: Trade Activity Log: Importing and Exporting Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
