Date/Time: Mon, 21 Sep 2026 22:39:01 +0000
Sierra Chart Data Feed question
View Count: 1240
| [2014-07-12 14:20:03] |
| bmoney - Posts: 32 |
I noticed that CTS T4 no longer allows historical tick data if the contract is expired. I also noticed that you guys have compensated for this by letting us download from your historical data servers. Even when I am looking at old charts I notice a download from your servers. Is all this data tick data? Or does it depend on the server it comes from?
| [2014-07-12 22:03:44] |
When using CTS T4, you are using Sierra Chart package 5, the Intraday Data Storage Time Unit is set to 1 Tick, then historical Intraday data downloaded for expired contracts is 1 tick per record.
