Date/Time: Wed, 27 Nov 2024 08:44:27 +0000
Adding Volume from 1 minute ago as a column to Quote Board
View Count: 347
[2023-08-21 21:31:22] |
User584005 - Posts: 27 |
Is there a way to add a column that shows the volume from the a minute ago to the Quoteboard. What i'm trying to accomplish is having a watchlist with that information in it updating every minute whether it be in a quoteboard or any other list available in the platform. |
[2023-08-22 15:04:11] |
John - SC Support - Posts: 36309 |
There is not a way to do it using the Quoteboard, as the fields in the Quoteboard are pre-set and that is not one of them. You could use the "Study Summary" window to display the information you are wanting. To do this, you would need to add a study that will have the data you want. There are a few ways to do this, the easiest would be to use the "Spreadsheet Formula" study and enter the following formula: =V[-1] This will give you the volume of the second to last bar. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-27 01:59:04] |
I did see the Study Summary and how it shows all charts currently open. This would work if I were able to open multiple charts quickly. I have watchlists that update as text files every 5-10 minutes. Is there a way I could take a list of symbols and have a chartbook automatically open each into their own preset chart? This way I would be able to constantly update that chartbook and in turn be use a study summary window as an up to date watchlist. Otherwise i would have to constantly keep opening each symbol into their own window and it would take too long to be useful. |
[2023-08-28 15:33:20] |
You can create a chartbook that has a chart for each symbol you want. Just open each chart individually. If you feel like there are too many charts to open manually, then you would have to create a custom study to open the charts you want. Refer to the following: sc.OpenChartOrGetChartReference() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
