Date/Time: Wed, 27 Nov 2024 10:51:54 +0000
No data
View Count: 215
[2023-08-21 17:33:17] |
KarimSanane - Posts: 10 |
Hello, I have been using my data for the past couple of days but now that I have turned on my PC the data is not displaying. I am currently successfully connected the folllowing is what I see on my screen. Please get this resolved asap.
No data.png / V - Attached On 2023-08-21 17:32:59 UTC - Size: 107.39 KB - 70 views Attachment Deleted. |
[2023-08-22 12:37:04] |
Sierra_Chart Engineering - Posts: 17191 |
You are not using the correct symbol. Translate the symbols with Edit >> Translate Symbols to Current Service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
