Date/Time: Wed, 27 Nov 2024 11:46:27 +0000
Error Dowload intraday DATA Zib
View Count: 368
[2023-08-20 22:43:36]
Hopeman - Posts: 166
When loading the graphics I get this error
Download failed Erroro downloading data historical intraday data for ESU23_FUT_CME historical data Zlib Error invalid literal/lengh code,
I have deleted and downloaded the data several times in the edit tab and even manually I have gone to symbol settings and I have done the Update from server, I have also installed a current version and a previous one and I have deleted all the data from the program and reinstalled Sierra again even so the problem persists and I cannot access the intraday data,
I would appreciate a little help on this aspect
Date Time Of Last Edit: 2023-08-20 22:45:12
imageZLIB.png / V - Attached On 2023-08-20 22:42:49 UTC - Size: 4.9 KB - 68 views
[2023-08-21 00:35:41]
Sierra_Chart Engineering - Posts: 17191
We see you are using Wine. Follow the instructions here to resolve this:
Resolution of Poor Network IO Performance under Linux/Wine
[2023-08-21 09:05:10]
Hi @Sierra_Chart Engineering, I use Crossover Codewavers It is the bridging program to which you refer to, is the solution the same?
Regards
Date Time Of Last Edit: 2023-08-21 15:41:30
[2023-08-21 16:22:48]
John - SC Support - Posts: 36309
If you are getting a Zlib error, then you need to turn off compression. Refer to the following:
Sierra Chart Server Settings: Use Real-Time Data Compression (Global Settings >> Sierra Chart Server Settings >> General >> General)
[2023-08-21 19:25:28]
Hi @John - SC Support!
It seems that the Zlib error has already disappeared, now another problem has arisen, the intraday charts do not load, in historical data it works fine but when I load an intraday chart it does not work, whatever the time frame, I have reviewed all the possibilities, downloaded the data, deleted data and reload I also went to update from server none of these options gave me the solutio
Date Time Of Last Edit: 2023-08-21 19:27:55
[2023-08-22 14:52:54]
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-08-23 06:45:23]
Software version: 2528 64-bit | 2023-08-23 08:37:22.179
Primary Thread ID: 280 | 2023-08-23 08:37:22.179
Usage end date: 2023-09-08 | 2023-08-23 08:37:22.179
Enabled for: Advanced Features 2. | 2023-08-23 08:37:22.179
Enabled for: Sierra Chart Historical Data Service. | 2023-08-23 08:37:22.179
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-08-23 08:37:22.179
Enabled for: Delayed Denali Exchange Data Feed. | 2023-08-23 08:37:22.179
Enabled for exchange2: CME | 2023-08-23 08:37:22.179
Enabled for exchange2: CFE | 2023-08-23 08:37:22.179
Enabled for exchange2: fairx_exchange.data | 2023-08-23 08:37:22.179
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-08-23 08:37:22.179
Current selected Data/Trading service: SC Data - All Services | 2023-08-23 08:37:22.179
Custom symbol settings values: enabled | 2023-08-23 08:37:22.179
Chart Update Interval: 500 | 2023-08-23 08:37:22.179
Intraday Data Storage Time Unit: 0 | 2023-08-23 08:37:22.179
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2023-08-23 08:37:22.179
2023-08-23 06:37:22 Local computer time in UTC | 2023-08-23 08:37:22.179
2023-08-23 08:37:22 Local computer time in SC Time Zone | 2023-08-23 08:37:22.179
2023-08-21 20:44:16 Server time in UTC | 2023-08-23 08:37:22.179
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-08-23 08:37:22.179
Program path: C:\SierraChart\ | 2023-08-23 08:37:22.179
Data Files path: Z:\Volumes\PCIe OSX\SC\Data\ | 2023-08-23 08:37:22.179
OS Version Number: 10.0 | 2023-08-23 08:37:22.179
Locale Setting: C | 2023-08-23 08:37:22.179
DLLs: UserContributedStudies_64.dll, VIX_64.dll, Zyp Free by Zyp_64.dll | 2023-08-23 08:37:22.181
Allowed protected custom studies: zyp_app | 2023-08-23 08:37:22.181
Crash reporter started: true | 2023-08-23 08:37:22.181
Socket (3) | CloseSocket call. | 2023-08-23 08:40:34.310
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-08-23 08:40:34.310
Historical data download thread signaled to stop. | 2023-08-23 08:40:34.310
HD Request # 45 | Received 46057797 Intraday data records from 2023-02-20 00:27:37.200000 to 2023-08-23 08:40:25.981000 (184.3 days. Delay: 8.3 seconds) and wrote 46057797 records for MNQU23-CME | 2023-08-23 08:40:34.311
HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2023-08-23 06:40:25.981000 | 2023-08-23 08:40:34.317
Added 25 Time and Sales records to Intraday data file for MNQU23-CME after download. | 2023-08-23 08:40:34.317
HD Request # 45 | Completion time: 4m 21s. | 2023-08-23 08:40:34.317
HD Request # 45 | Intraday data download complete for MNQU23-CME. Unique request ID: 45 | 2023-08-23 08:40:34.317
Removing historical data download ID 45. | 2023-08-23 08:40:34.317
Real-time Intraday chart data file updates started for MNQU23-CME | 2023-08-23 08:40:34.317
Intraday chart data file opened for MNQU23-CME | 2023-08-23 08:40:34.317
HD Request # 45 | Enabling Intraday chart updating for symbol. | 2023-08-23 08:40:34.317
Triggering next historical data download in queue. | 2023-08-23 08:40:34.317
No download requests in the queue to start downloads for. | 2023-08-23 08:40:34.317
Socket (3) | Socket gracefully closed by remote side. | 2023-08-23 08:40:34.433
Socket (3) | Closed. | 2023-08-23 08:40:34.433
Opened cached Intraday file: Z:\Volumes\PCIe OSX\SC\Data\MNQU23-CME.scid. Thread ID: 368 | 2023-08-23 08:40:36.450
#1 GEU23-CME 1 Min | Reloading chart. | 2023-08-23 08:42:35.046
#1 GEU23-CME 1 Min | Currently no data in file to display. Will start historical data download and real-time updates. File: Z:\Volumes\PCIe OSX\SC\Data\GEU23-CME.scid | 2023-08-23 08:42:35.066
Mapping GEU23-CME to GEU23. Service code: cme | 2023-08-23 08:42:35.499
Denali Data Feed | Starting real-time market data updates for: GEU23-CME (GEU23). ID: 12 Service code: cme | 2023-08-23 08:42:35.499
Denali Data Feed | Requesting security definition data for: GEU23-CME (GEU23). ID: 12 | 2023-08-23 08:42:35.499
Added historical Intraday data request for GEU23-CME to the queue. | 2023-08-23 08:42:35.499
Intraday data recording state for symbol GEU23-CME is set to download 'Pending'. | 2023-08-23 08:42:35.499
Triggering next historical data download in queue. | 2023-08-23 08:42:35.500
Delaying start of download for GEU23-CME. | 2023-08-23 08:42:35.528
Denali Data Feed | Real-time data for symbol GEU23-CME is currently unavailable. | 2023-08-23 08:42:35.723
Denali Data Feed | Received security definition for symbol GEU23-CME | 2023-08-23 08:42:35.723
HD Request # 46 | Downloading Intraday chart data for GEU23-CME to the file GEU23-CME.scid. Service: cme | 2023-08-23 08:42:40.641
HD Request # 46 | Download start date-time: 2023-02-18 07:42:40.000000. File last date-time: 00:00:00.000000 | 2023-08-23 08:42:40.642
HD Request # 46 | Using server: ds26.sierracharts.com port 10149 | 2023-08-23 08:42:40.642
Socket (3) | Creating socket. | 2023-08-23 08:42:40.658
Socket (3) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2023-08-23 08:42:40.659 *
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-08-23 08:42:40.659
HD Request # 46 | Setting DTC encoding to Binary VLS | 2023-08-23 08:42:40.906
HD Request # 46 | Sending historical data logon request message. | 2023-08-23 08:42:40.906
HD Request # 46 | Requesting Intraday data. Start date-time: 2023-02-18 07:42:40. Record interval: 0. Symbol: GEU23 | 2023-08-23 08:42:41.559
HD Request # 46 | Decompressing data. | 2023-08-23 08:42:41.683
HD Request # 46 | Receiving Intraday data for GEU23-CME starting at 2023-02-20 00:00:00.240000 | 2023-08-23 08:42:41.699
HD Request # 46 | Timestamp of first Intraday data file record written: 2023-02-20 00:00:00.240000. | 2023-08-23 08:42:42.173
Socket (3) | CloseSocket call. | 2023-08-23 08:42:43.641
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-08-23 08:42:43.641
Historical data download thread signaled to stop. | 2023-08-23 08:42:43.641
HD Request # 46 | Received 218314 Intraday data records from 2023-02-20 00:00:00.240000 to 2023-04-14 22:57:52.255000 (53.9 days. Delay: 130.4 days) and wrote 218314 records for GEU23-CME | 2023-08-23 08:42:43.642
HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2023-04-14 20:57:52.255000 | 2023-08-23 08:42:43.647
HD Request # 46 | Completion time: 3s. | 2023-08-23 08:42:43.647
HD Request # 46 | Intraday data download complete for GEU23-CME. Unique request ID: 46 | 2023-08-23 08:42:43.647
Removing historical data download ID 46. | 2023-08-23 08:42:43.647
Real-time Intraday chart data file updates started for GEU23-CME | 2023-08-23 08:42:43.647
Intraday chart data file opened for GEU23-CME | 2023-08-23 08:42:43.647
HD Request # 46 | Enabling Intraday chart updating for symbol. | 2023-08-23 08:42:43.647
Triggering next historical data download in queue. | 2023-08-23 08:42:43.647
No download requests in the queue to start downloads for. | 2023-08-23 08:42:43.647
Socket (3) | Socket gracefully closed by remote side. | 2023-08-23 08:42:43.763
Socket (3) | Closed. | 2023-08-23 08:42:43.763
File >> Disconnect selected. | 2023-08-23 08:43:29.735
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-23 08:43:29.736
DTC Client socket (1) | CloseSocket call. | 2023-08-23 08:43:29.736
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-23 08:43:29.736
Denali Data Feed | Disconnected from the server. | 2023-08-23 08:43:29.736
DTC Client socket (2) | CloseSocket call. | 2023-08-23 08:43:29.737
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-08-23 08:43:29.737
Denali Data Feed | Disconnected from the server. | 2023-08-23 08:43:29.737
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2023-08-23 08:43:29.737
DTC Client socket (4) | CloseSocket call. | 2023-08-23 08:43:29.737
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-08-23 08:43:29.737
SC DTC Data with Market Depth | Disconnected from the server. | 2023-08-23 08:43:29.737
SC Data - All Services | Disconnected. | 2023-08-23 08:43:29.737
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-08-23 08:43:29.830
DTC Client socket (2) | Closed. | 2023-08-23 08:43:29.830
DTC Client socket (4) | Socket gracefully closed by remote side. | 2023-08-23 08:43:29.857
DTC Client socket (4) | Closed. | 2023-08-23 08:43:29.857
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-23 08:43:29.974
DTC Client socket (1) | Closed. | 2023-08-23 08:43:29.974
SC Data - All Services | Connected to server complete. | 2023-08-23 08:43:37.426
Triggering next historical data download in queue. | 2023-08-23 08:43:37.426
No download requests in the queue to start downloads for. | 2023-08-23 08:43:37.427
Mapping GEU23-CME to GEU23. Service code: cme | 2023-08-23 08:43:37.501
Using symbol data fast lookup vector | 2023-08-23 08:43:37.501
Denali Data Feed | Starting real-time market data updates for: GEU23-CME (GEU23). ID: 1 Service code: cme | 2023-08-23 08:43:37.501
Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 10048 | 2023-08-23 08:43:37.501
Denali Data Feed | Requesting security definition data for: GEU23-CME (GEU23). ID: 1 | 2023-08-23 08:43:37.501
Added historical Intraday data request for GEU23-CME to the queue. | 2023-08-23 08:43:37.501
Intraday data recording state for symbol GEU23-CME is set to download 'Pending'. | 2023-08-23 08:43:37.501
Triggering next historical data download in queue. | 2023-08-23 08:43:37.501
Delaying start of download for GEU23-CME. | 2023-08-23 08:43:37.513
DTC Client socket (1) | Creating socket. | 2023-08-23 08:43:37.534
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2023-08-23 08:43:37.534 *
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-08-23 08:43:37.535
Denali Data Feed | Network connection to server complete. | 2023-08-23 08:43:37.681
Denali Data Feed | Starting socket receive thread. | 2023-08-23 08:43:37.681
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-23 08:43:37.681
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-23 08:43:37.830
Denali Data Feed | Sending logon request message. | 2023-08-23 08:43:37.830
Denali Data Feed | Received logon response. | 2023-08-23 08:43:38.004
Denali Data Feed | Server Name: RealTime Server. | 2023-08-23 08:43:38.004
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-23 08:43:38.004
Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-08-23 08:43:38.004
Denali Data Feed | Failed connections: 1 | 2023-08-23 08:43:38.004
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-23 08:43:38.004
DTC Client socket (1) | CloseSocket call. | 2023-08-23 08:43:38.005
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-23 08:43:38.005
Denali Data Feed | Disconnected from the server. | 2023-08-23 08:43:38.005
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-08-23 08:43:38.005
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-23 08:43:38.149
DTC Client socket (1) | Closed. | 2023-08-23 08:43:38.149
Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048 | 2023-08-23 08:43:40.005
DTC Client socket (1) | Creating socket. | 2023-08-23 08:43:40.044
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2023-08-23 08:43:40.045 *
DTC Client socket (1) | Connecting to IP: 142.215.17.189. | 2023-08-23 08:43:40.045
Denali Data Feed | Network connection to server complete. | 2023-08-23 08:43:40.164
Denali Data Feed | Starting socket receive thread. | 2023-08-23 08:43:40.164
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-23 08:43:40.164
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-23 08:43:40.303
Denali Data Feed | Sending logon request message. | 2023-08-23 08:43:40.303
Denali Data Feed | Received logon response. | 2023-08-23 08:43:41.209
Denali Data Feed | Server Name: SC Realtime Server. | 2023-08-23 08:43:41.209
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-23 08:43:41.209
Denali Data Feed | Successfully connected. | 2023-08-23 08:43:41.209
Denali Data Feed | Trading is not supported. | 2023-08-23 08:43:41.209
Denali Data Feed | Restarting real-time data updates for symbol: GEU23-CME -> GEU23 | 2023-08-23 08:43:41.209
Denali Data Feed | Real-time data for symbol GEU23-CME is currently unavailable. | 2023-08-23 08:43:41.428
Denali Data Feed | Received security definition for symbol GEU23-CME | 2023-08-23 08:43:41.428
HD Request # 47 | Downloading Intraday chart data for GEU23-CME to the file GEU23-CME.scid. Service: cme | 2023-08-23 08:43:46.643
HD Request # 47 | Download start date-time: 2023-04-14 22:57:52.000000. File last date-time: 2023-04-14 22:57:52.255000 | 2023-08-23 08:43:46.644
HD Request # 47 | Using server: ds28.sierracharts.com port 10150 | 2023-08-23 08:43:46.644
Socket (2) | Creating socket. | 2023-08-23 08:43:46.645
Socket (2) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2023-08-23 08:43:46.645 *
Socket (2) | Connecting to IP: 142.215.18.147. | 2023-08-23 08:43:46.646
HD Request # 47 | Setting DTC encoding to Binary VLS | 2023-08-23 08:43:46.887
HD Request # 47 | Sending historical data logon request message. | 2023-08-23 08:43:46.887
HD Request # 47 | Requesting Intraday data. Start date-time: 2023-04-14 22:57:52. Record interval: 0. Symbol: GEU23 | 2023-08-23 08:43:47.553
HD Request # 47 | Decompressing data. | 2023-08-23 08:43:47.685
HD Request # 47 | Receiving Intraday data for GEU23-CME starting at 2023-04-14 22:57:52.255000 | 2023-08-23 08:43:47.803
Socket (2) | CloseSocket call. | 2023-08-23 08:43:47.803
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-08-23 08:43:47.804
Historical data download thread signaled to stop. | 2023-08-23 08:43:47.804
HD Request # 47 | Received 1 Intraday data record from 2023-04-14 22:57:52.255000 to 2023-04-14 22:57:52.255000 (0.0 seconds. Delay: 130.4 days) and wrote 0 records for GEU23-CME | 2023-08-23 08:43:47.804
HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2023-04-14 20:57:52.255000 | 2023-08-23 08:43:47.804
HD Request # 47 | Completion time: 1s. | 2023-08-23 08:43:47.804
HD Request # 47 | Intraday data download complete for GEU23-CME. Unique request ID: 47 | 2023-08-23 08:43:47.804
Removing historical data download ID 47. | 2023-08-23 08:43:47.804
Real-time Intraday chart data file updates started for GEU23-CME | 2023-08-23 08:43:47.804
Intraday chart data file opened for GEU23-CME | 2023-08-23 08:43:47.805
HD Request # 47 | Enabling Intraday chart updating for symbol. | 2023-08-23 08:43:47.805
Triggering next historical data download in queue. | 2023-08-23 08:43:47.805
No download requests in the queue to start downloads for. | 2023-08-23 08:43:47.805
Socket (2) | Socket gracefully closed by remote side. | 2023-08-23 08:43:47.923
Socket (2) | Closed. | 2023-08-23 08:43:47.923
[2023-08-23 11:54:00]
You must follow this solution:
[2023-08-23 13:18:36]
Hello, I would like to understand the problem a little better!
Poor Network means that I have a low internet network or is it because of the bridge program in this case Crossover?
Kind regards
[2023-08-23 13:35:10]
Yes because you are using crossover. You are actually using Wine.
Date Time Of Last Edit: 2023-08-23 13:35:18
[2023-08-24 13:56:40]
Thanks team seems to have solved the problem
[2023-08-25 19:48:01]
User805074 - Posts: 29
Thanks you in Trading Evaluator Delayed, fixed problem.
