Date/Time: Sun, 08 Sep 2024 00:12:49 +0000
Draw in a separate space to the right of the chart
View Count: 235
[2023-08-20 06:12:25] |
es10pt - Posts: 7 |
Please tell me how to allocate a separate space on the right side of the chart and draw a line there, as shown in the attached image.
Attachment Deleted. |
[2023-08-21 15:26:36] |
To lock the space on the right, use the "Lock Fill Space" option. Refer to the following: Working With Charts: Right Side Fill Space We can not say exactly how the lines were placed in the image provided. Given the space that exists between the last bar and the beginning of the drawing, they appear to be line drawings. But, if you are working with studies (subgraphs) then you can specify a "Draw Type" of "Line at Last Bar to Edge" which will give you a similar look, except that it starts at the last bar, not a certain space over. Refer to the following: Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
