Date/Time: Sun, 08 Sep 2024 00:10:32 +0000
ABS Of Delta
View Count: 320
[2023-08-19 03:06:07] |
Oz - Posts: 49 |
I'm new to Sierra. Maybe there is a study for this or a setting in an existing study. I'd like to plot the absolute delta of each bar and then use this data for other purposes. Hence all values to be shown as positive (drawn as a positive bar even if delta is negative). I've tried ask/bid volume difference bars study, but this shows the negative values as well. What's the most efficient way to do this? Thank you. |
[2023-08-19 08:20:17] |
User431178 - Posts: 495 |
Did you try spreadsheet formula study? Spreadsheet Formula =ABS(AV-BV) |
[2023-08-19 14:34:16] |
Oz - Posts: 49 |
Thank you, that did the trick. Brilliant and simple. |
