Date/Time: Sun, 08 Sep 2024 00:04:25 +0000
Labels/description on a chart
View Count: 256
[2023-08-18 22:15:30] |
User469312 - Posts: 96 |
My question is, is there a way that I can hide information on my chart. For instance, a ESU23 60 min chart, is there a way I can hide the label on the chart where it says 60 MIN? Or if a Renko chart, can I hide the Renko label on the chart? Just trying to reduce the amount of info on the chart Thank You |
[2023-08-19 16:28:58] |
user_xyz - Posts: 400 |
Global Settings -> Customize Chart Header. That should do the trick
