Date/Time: Mon, 16 Sep 2024 19:21:37 +0000
Continuous Futures Contract - not working with 1156
View Count: 987
[2014-07-11 17:51:39] |
User35670 - Posts: 2 |
I cannot create a Continuous Futures Contract (Volume & Volume/Backadjusted) with version 1156. Only the spot month appears on the chart. I am using an Interactive Brokers datafeed. With version 1137 there are no problems. Any suggestions, please.
[2014-07-11 23:10:23] |
There should be no problem with this. We recommend performing a re-download of all data for all contract months for the chart. Here are the instructions for this: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
