Date/Time: Mon, 16 Sep 2024 19:18:40 +0000
no top of the windows
View Count: 955
[2014-07-11 16:47:20] |
TradingMarketProfile - Posts: 120 |
hello, Can you tell me how can i setup the windows in the chartbook with no top of the windows (see picture) Thanks Date Time Of Last Edit: 2014-07-11 16:47:57
Capture.PNG / V - Attached On 2014-07-11 16:47:07 UTC - Size: 131.57 KB - 325 views |
[2014-07-11 17:10:05] |
There is a command on the Chart menu for this: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#ShowTitleBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-11 17:24:58] |
Great thanks
