Date/Time: Sun, 08 Sep 2024 00:16:51 +0000
display VbP
View Count: 404
[2023-08-17 09:52:52] |
stephane1 - Posts: 110 |
Good morning I would like to have a fixed volume by price display, when a volume is much larger than the rest of the other volumes, they disappear, I have to increase the size of the window. Is there a way to fix this without increasing the window size? . THANKS |
[2023-08-17 13:08:47] |
There are multiple options for how the Volume by Price profile is displayed relative to the screen. In particular, refer to the following Input and the one just below it: Volume By Price Study: Maximum Volume Bar Width Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-19 03:15:22] |
Tony - Posts: 502 |
I assume you are trading stocks: There are 2 possible solutions to address this issue, 1, first way was mentioned by a user named 'funbun' is to increase 'ticks per volume bar' up to 20+, discussions can be found here. 2, second way is to increase 'Maximum Volume Bar Width Percentage', Engineering team increased that number from 100 to 500, discussions can be found here. |
