Date/Time: Wed, 27 Nov 2024 10:26:40 +0000
Internet Download Speed Test vs Sierra Chart Download Speed
View Count: 366
[2023-08-17 01:49:38] |
Poblano Trading Capital - Posts: 15 |
When I open the task manager in my computer, click in the [performance tab] and then I run a internet speed download test on any website, I can see my ethernet card hitting >500Mbps download. While using Sierra Chart, when I download a historical TPO Profile Chart Study, 1 single period of 2 years data, I can see in the same task manager, in the [performance tab] that the same ethernet card is running at <50Mbps, which is incredibly slower compare to the download test. What can I do to download faster from your server?, currently is 10% of my bandwidth, Is there any other option/server I can use? even if I need to pay for the faster connection. Thanks for your time and feedback. |
[2023-08-17 10:54:22] |
VLiviu - Posts: 223 |
your download speed is something and the sc's upload is something else :)
[2023-08-17 13:10:39] |
John - SC Support - Posts: 36309 |
Also, you would have to ensure that you were actually downloading the data from our servers and not just loading it from your drive.
[2023-08-17 14:15:41] |
Sierra_Chart Engineering - Posts: 17191 |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
