Date/Time: Wed, 27 Nov 2024 10:32:48 +0000
Need help with DOM customization
View Count: 340
[2023-08-17 01:31:34] |
Jaydtrade - Posts: 87 |
I cannot seem to figure out how to get my VP on the left to the right side of the dom? I thought it would chart region but when I put it to 2 nothing happens
MOVE VP OVER.png / V - Attached On 2023-08-17 01:31:28 UTC - Size: 110.97 KB - 77 views |
[2023-08-17 12:57:39] |
John - SC Support - Posts: 36309 |
There is no support to put the Volume Profile on the right side of the DOM.
[2023-08-17 13:30:39] |
IF that's the case then why does this person have it on theirs?
VP RIGHT.png / V - Attached On 2023-08-17 13:30:34 UTC - Size: 51.57 KB - 76 views |
[2023-08-17 15:04:05] |
That is a profile of the data in that column. Refer to the information here: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-17 15:09:26] |
OKay thank you I will check it out
