Date/Time: Wed, 27 Nov 2024 10:46:01 +0000
custom symbol settings
View Count: 270
[2023-08-16 23:56:28] |
WeroTrader - Posts: 46 |
Greetings, Sierra Chart team. I have been manually updating some symbols and my question is if it is possible to share the modified symbols file by linking it in my list of authorized users. Same question regarding the watch list of symbols. Thanks for your reply. |
[2023-08-17 12:07:25] |
Sierra_Chart Engineering - Posts: 17191 |
What symbols are you referring to? In the Global Symbol Settings? The watchlist of symbols is held within a Chartbook. You can share a Chartbook for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
