Date/Time: Wed, 27 Nov 2024 10:47:26 +0000
import trade activity to trade activity log
View Count: 418
[2023-08-16 17:43:52]
User553413 - Posts: 60
I exported trade activity into the trade activity log, and then I cleared the trade activity. When I tried to imort the trade activity, I couldn't import it. Please helpme to import the trade activity. I can import the trade activity into my trading journal at tradesynch.com, but I can't import it back into sierra chart trade actvity. I attached the message log. I am not getting anything useful from it. please send me a request and I can send my message log for analysis.
imageScreenshot 2023-08-16 133730.png / V - Attached On 2023-08-16 17:38:48 UTC - Size: 59.23 KB - 83 views
[2023-08-16 19:35:09]
John - SC Support - Posts: 36309
Make sure there is a blank line at the very end of the file. That is, go to the last line in the file and at the end of the line, select the "Enter" key to put in a blank line at the end.
The other thing to keep in mind is that the format needs to match the format of an "Exported" file. Refer to the following:
Trade Activity Log: Importing and Exporting Data
[2023-08-16 20:16:21]
I opened the text, and put an extra blank line at the end by pressing etner. I exported the trade activity from sierra chart sim account, so the format is the same as it was when I got it from trade activity log. The message log says that there are 0 sim trades and non sim trades. That is not accurate. What could be the issue?
Date Time Of Last Edit: 2023-08-16 20:18:05
[2023-08-16 20:20:20]
Keep in mind that only Fills are imported. So if you do not have any fills in the log, then there is nothing to import back in.
Otherwise, you can attach your file to this thread (you can attach it privately if you wish) and we will take a look and see what might be going on. Refer to the following for how to attach a file:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2023-08-16 20:24:15]
OK I am sending the trade activity file.
attachmentTradeActivityLog_2023_8_16.txt - Attached On 2023-08-16 20:23:44 UTC - Size: 15.09 KB - 147 views
[2023-08-16 20:40:43]
What is in the file is the "Trades" page from the Trade Activity Log. This can not be reimported. The only items that can be imported are the "Fills" that are "Exported" from the 'Trade Activity' page.
