Date/Time: Wed, 27 Nov 2024 10:34:55 +0000
DOM on second instance has no data
View Count: 306
[2023-08-16 12:10:53]
bitzbytz786 - Posts: 11
I copied SC installation of one computer to another, I started SC on second computer. How ever I am not able to see DOM data (all the bid ask and pull back column) in second installation.
I have a package service of Allowed Systems:  2 out of a total of 3 system(s) are currently being used.
Can you please help if I have the right service package
https://www.sierrachart.com/image.php?Image=1692187937479.png
Thanks,
Srinath
Date Time Of Last Edit: 2023-08-16 12:12:45
[2023-08-16 13:27:37]
John - SC Support - Posts: 36309
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-08-16 14:22:55]
Hi John,
Here is the log following the instructions posted.
I have 3 connections and 2 connections active. How do I get Market depth for 2 connections
I see below 3 errors
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:20:33.535
Requesting market depth updates for: ESU23-CME if supported. NumLevels=100 | 2023-08-16 14:17:45.264
Separate subscription for market depth updates not supported. ESU23-CME | 2023-08-16 14:17:45.265
Software version: 2537 64-bit | 2023-08-16 14:16:49.359
Primary Thread ID: 24508 | 2023-08-16 14:16:49.359
Usage end date: 2023-08-25 | 2023-08-16 14:16:49.359
Enabled for: Advanced Features 2. | 2023-08-16 14:16:49.359
Enabled for: Sierra Chart Historical Data Service. | 2023-08-16 14:16:49.359
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-08-16 14:16:49.359
Enabled for: Delayed Denali Exchange Data Feed. | 2023-08-16 14:16:49.359
Enabled for exchange2: CME (Trading Account Required) | 2023-08-16 14:16:49.359
Enabled for exchange2: CBOT (Trading Account Required) | 2023-08-16 14:16:49.359
Enabled for exchange2: COMEX (Trading Account Required) | 2023-08-16 14:16:49.359
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-08-16 14:16:49.359
Enabled for exchange2: fairx_exchange.data | 2023-08-16 14:16:49.359
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-08-16 14:16:49.359
Current selected Data/Trading service: SC Data - All Services | 2023-08-16 14:16:49.359
Custom symbol settings values: enabled | 2023-08-16 14:16:49.359
Chart Update Interval: 500 | 2023-08-16 14:16:49.359
Intraday Data Storage Time Unit: 1 | 2023-08-16 14:16:49.359
Time Zone: +00:00:00 (UTC+00) | 2023-08-16 14:16:49.359
2023-08-16 14:16:49 Local computer time in UTC | 2023-08-16 14:16:49.359
2023-08-16 14:16:49 Local computer time in SC Time Zone | 2023-08-16 14:16:49.359
2023-08-16 14:15:38 Server time in UTC | 2023-08-16 14:16:49.359
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-08-16 14:16:49.359
Program path: \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\ | 2023-08-16 14:16:49.359
Data Files path: \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\Data\ | 2023-08-16 14:16:49.359
OS Version Number: 10.0 | 2023-08-16 14:16:49.360
Locale Setting: C | 2023-08-16 14:16:49.362
DLLs: UserContributedStudies_64.dll, TWFX_FREE_ZZS_64.dll, TWFX_FREE_SWS_64.dll, TWFX_FREE_64.dll, sst_FreeBundle_64.dll | 2023-08-16 14:16:49.363
Allowed protected custom studies: SST_FreeBundle, TWFX_Free | 2023-08-16 14:16:49.363
Crash reporter started: true | 2023-08-16 14:16:49.363
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 | 2023-08-16 14:16:52.359
DTC Client socket (1) | Creating socket. | 2023-08-16 14:16:52.441
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:16:52.441
DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-08-16 14:16:52.441
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:16:52.737
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:16:52.738
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:16:52.739
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:16:52.998
Denali Data Feed | Sending logon request message. | 2023-08-16 14:16:52.998
Denali Data Feed | Received logon response. | 2023-08-16 14:16:53.943
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:16:53.943
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:16:53.943
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:16:53.943
Denali Data Feed | Failed connections: 3 | 2023-08-16 14:16:53.943
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:16:53.943
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:16:53.945
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:16:53.946
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:16:53.946
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:16:53.946
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:16:54.179
DTC Client socket (1) | Closed. | 2023-08-16 14:16:54.180
Saved Chartbook: ExampleChartbook.cht. Time: 0.0042 seconds. | 2023-08-16 14:17:07.122
Unsubscribed from market depth data for ESU23-CME | 2023-08-16 14:17:10.215
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 | 2023-08-16 14:17:23.948
DTC Client socket (1) | Creating socket. | 2023-08-16 14:17:23.962
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:17:23.963
DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-08-16 14:17:23.963
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:17:24.210
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:17:24.210
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:17:24.211
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:17:24.476
Denali Data Feed | Sending logon request message. | 2023-08-16 14:17:24.476
Denali Data Feed | Received logon response. | 2023-08-16 14:17:25.392
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:17:25.392
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:17:25.392
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:17:25.392
Denali Data Feed | Failed connections: 4 | 2023-08-16 14:17:25.392
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:17:25.392
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:17:25.393
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:17:25.393
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:17:25.393
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:17:25.393
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:17:25.629
DTC Client socket (1) | Closed. | 2023-08-16 14:17:25.630
File compression not supported on file system. \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\Data\ESU23-CME.scid. Windows error code 1: Incorrect function. | 2023-08-16 14:17:26.389
ESU23-CME 1 Min #1 | Reloading chart. | 2023-08-16 14:17:26.392
File compression not supported on file system. \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\Data\ESU23-CME.scid. Windows error code 1: Incorrect function. | 2023-08-16 14:17:26.396
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-08-16 14:17:55.388
DTC Client socket (1) | Creating socket. | 2023-08-16 14:17:55.460
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:17:55.461
DTC Client socket (1) | Connecting to IP: 142.215.18.148. | 2023-08-16 14:17:55.461
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:17:55.702
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:17:55.702
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:17:55.702
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:17:55.983
Denali Data Feed | Sending logon request message. | 2023-08-16 14:17:55.983
Denali Data Feed | Received logon response. | 2023-08-16 14:17:56.904
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:17:56.904
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:17:56.904
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:17:56.904
Denali Data Feed | Failed connections: 5 | 2023-08-16 14:17:56.904
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:17:56.904
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:17:56.906
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:17:56.906
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:17:56.906
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:17:56.907
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:17:57.135
DTC Client socket (1) | Closed. | 2023-08-16 14:17:57.135
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-08-16 14:18:26.927
DTC Client socket (1) | Creating socket. | 2023-08-16 14:18:26.935
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:18:26.935
DTC Client socket (1) | Connecting to IP: 142.215.18.148. | 2023-08-16 14:18:26.935
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:18:27.173
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:18:27.173
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:18:27.173
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:18:27.440
Denali Data Feed | Sending logon request message. | 2023-08-16 14:18:27.440
Denali Data Feed | Received logon response. | 2023-08-16 14:18:28.352
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:18:28.352
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:18:28.352
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:18:28.352
Denali Data Feed | Failed connections: 6 | 2023-08-16 14:18:28.352
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:18:28.352
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:18:28.353
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:18:28.353
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:18:28.353
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:18:28.353
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:18:28.584
DTC Client socket (1) | Closed. | 2023-08-16 14:18:28.585
File >> Disconnect selected. | 2023-08-16 14:18:49.482
DTC Client socket (0) | CloseSocket call. | 2023-08-16 14:18:49.492
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:18:49.492
SC Data - All Services | Disconnected. | 2023-08-16 14:18:49.498
SC Data - All Services | Connected to server complete. | 2023-08-16 14:18:54.206
Triggering next historical data download in queue. | 2023-08-16 14:18:54.207
No download requests in the queue to start downloads for. | 2023-08-16 14:18:54.208
Mapping ESU23-CME to ESU23. Service code: cme | 2023-08-16 14:18:54.666
Using symbol data fast lookup vector | 2023-08-16 14:18:54.666
Denali Data Feed | Starting real-time market data updates for: ESU23-CME (ESU23). ID: 1 Service code: cme | 2023-08-16 14:18:54.667
Denali Data Feed | Connecting to the server ds23.sierracharts.com. Port 443 | 2023-08-16 14:18:54.668
Denali Data Feed | Requesting security definition data for: ESU23-CME (ESU23). ID: 1 | 2023-08-16 14:18:54.668
Added historical Intraday data request for ESU23-CME to the queue. | 2023-08-16 14:18:54.669
Intraday data recording state for symbol ESU23-CME is set to download 'Pending'. | 2023-08-16 14:18:54.669
Triggering next historical data download in queue. | 2023-08-16 14:18:54.669
DTC Client socket (1) | Creating socket. | 2023-08-16 14:18:54.727
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:18:54.727
DTC Client socket (1) | Connecting to IP: 142.215.17.190. | 2023-08-16 14:18:54.728
Delaying start of download for ESU23-CME. | 2023-08-16 14:18:54.775
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:18:54.973
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:18:54.973
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:18:54.973
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:18:55.235
Denali Data Feed | Sending logon request message. | 2023-08-16 14:18:55.235
Denali Data Feed | Received logon response. | 2023-08-16 14:18:56.172
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:18:56.172
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:18:56.172
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:18:56.172
Denali Data Feed | Failed connections: 7 | 2023-08-16 14:18:56.172
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:18:56.172
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:18:56.173
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:18:56.173
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:18:56.173
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:18:56.173
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:18:56.411
DTC Client socket (1) | Closed. | 2023-08-16 14:18:56.412
Requesting market depth updates for: ESU23-CME if supported. NumLevels=100 | 2023-08-16 14:18:59.217
Separate subscription for market depth updates not supported. ESU23-CME | 2023-08-16 14:18:59.217
HD Request # 2 | Downloading Intraday chart data for ESU23-CME to the file ESU23-CME.scid. Service: cme | 2023-08-16 14:19:25.402
File compression not supported on file system. \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\Data\ESU23-CME.scid. Windows error code 1: Incorrect function. | 2023-08-16 14:19:25.408
HD Request # 2 | Download start date-time: 2023-08-16 14:16:41.000000. File last date-time: 2023-08-16 14:16:41.499000 | 2023-08-16 14:19:25.413
HD Request # 2 | Using server: ds28.sierracharts.com port 10150 | 2023-08-16 14:19:25.414
Socket (1) | Creating socket. | 2023-08-16 14:19:25.419
Socket (1) | New receive buffer size: 0 | 2023-08-16 14:19:25.421
Socket (1) | Connecting to IP: 142.215.18.147. | 2023-08-16 14:19:25.421
HD Request # 2 | Setting DTC encoding to Binary VLS | 2023-08-16 14:19:25.918
HD Request # 2 | Sending historical data logon request message. | 2023-08-16 14:19:25.918
Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048 | 2023-08-16 14:19:26.194
DTC Client socket (2) | Creating socket. | 2023-08-16 14:19:26.218
DTC Client socket (2) | New receive buffer size: 0 | 2023-08-16 14:19:26.218
DTC Client socket (2) | Connecting to IP: 142.215.17.188. | 2023-08-16 14:19:26.218
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:19:26.467
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:19:26.467
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:19:26.469
HD Request # 2 | Requesting Intraday data. Start date-time: 2023-08-16 14:16:41. Record interval: 1. Symbol: ESU23 | 2023-08-16 14:19:26.695
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:19:26.769
Denali Data Feed | Sending logon request message. | 2023-08-16 14:19:26.769
HD Request # 2 | Decompressing data. | 2023-08-16 14:19:26.939
HD Request # 2 | Receiving Intraday data for ESU23-CME starting at 2023-08-16 14:16:41.499000 | 2023-08-16 14:19:27.182
Socket (1) | CloseSocket call. | 2023-08-16 14:19:27.188
Socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:19:27.189
Historical data download thread signaled to stop. | 2023-08-16 14:19:27.189
HD Request # 2 | Timestamp of first Intraday data file record written: 2023-08-16 14:16:41.499000. | 2023-08-16 14:19:27.196
HD Request # 2 | Received 155 Intraday data records from 2023-08-16 14:16:41.499000 to 2023-08-16 14:19:24.599000 (2.7 minutes. Delay: 2.6 seconds) and wrote 155 records for ESU23-CME | 2023-08-16 14:19:27.197
File compression not supported on file system. \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\Data\ESU23-CME.scid. Windows error code 1: Incorrect function. | 2023-08-16 14:19:27.204
HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2023-08-16 14:19:24.599000 | 2023-08-16 14:19:27.208
HD Request # 2 | Completion time: 2s. | 2023-08-16 14:19:27.208
HD Request # 2 | Intraday data download complete for ESU23-CME. Unique request ID: 2 | 2023-08-16 14:19:27.208
Removing historical data download ID 2. | 2023-08-16 14:19:27.208
Real-time Intraday chart data file updates started for ESU23-CME | 2023-08-16 14:19:27.208
File compression not supported on file system. \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\Data\ESU23-CME.scid. Windows error code 1: Incorrect function. | 2023-08-16 14:19:27.210
Opened cached Intraday file: \\.psf\Home\Desktop\Sandbox\2537\SierraChart2537\Data\ESU23-CME.scid. Thread ID: 24508 | 2023-08-16 14:19:27.211
Intraday chart data file opened for ESU23-CME | 2023-08-16 14:19:27.211
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2023-08-16 14:19:27.212
Triggering next historical data download in queue. | 2023-08-16 14:19:27.212
Historical data for ESU23-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-08-16 14:19:27.212
No download requests in the queue to start downloads for. | 2023-08-16 14:19:27.212
Socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:19:27.430
Socket (1) | Closed. | 2023-08-16 14:19:27.430
Denali Data Feed | Received logon response. | 2023-08-16 14:19:27.716
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:19:27.716
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:19:27.716
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:19:27.716
Denali Data Feed | Failed connections: 8 | 2023-08-16 14:19:27.716
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:19:27.716
DTC Client socket (2) | CloseSocket call. | 2023-08-16 14:19:27.726
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:19:27.726
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:19:27.726
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:19:27.727
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-08-16 14:19:27.954
DTC Client socket (2) | Closed. | 2023-08-16 14:19:27.955
Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 443 | 2023-08-16 14:19:57.721
DTC Client socket (1) | Creating socket. | 2023-08-16 14:19:57.781
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:19:57.781
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-08-16 14:19:57.781
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:19:58.059
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:19:58.059
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:19:58.060
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:19:58.357
Denali Data Feed | Sending logon request message. | 2023-08-16 14:19:58.357
Denali Data Feed | Received logon response. | 2023-08-16 14:19:58.640
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:19:58.641
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:19:58.641
Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-08-16 14:19:58.641
Denali Data Feed | Failed connections: 9 | 2023-08-16 14:19:58.641
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:19:58.641
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:19:58.643
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:19:58.643
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-08-16 14:19:58.643
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:19:58.643
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:19:58.917
DTC Client socket (1) | Closed. | 2023-08-16 14:19:58.917
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10048 | 2023-08-16 14:20:00.655
DTC Client socket (1) | Creating socket. | 2023-08-16 14:20:00.663
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:20:00.663
DTC Client socket (1) | Connecting to IP: 142.215.17.187. | 2023-08-16 14:20:00.663
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:20:00.903
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:20:00.903
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:20:00.903
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:20:01.170
Denali Data Feed | Sending logon request message. | 2023-08-16 14:20:01.170
Denali Data Feed | Received logon response. | 2023-08-16 14:20:02.110
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:20:02.110
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:20:02.110
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-08-16 14:20:02.110
Denali Data Feed | Failed connections: 10 | 2023-08-16 14:20:02.110
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:20:02.110
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:20:02.112
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:20:02.112
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:20:02.112
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:20:02.112
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:20:02.346
DTC Client socket (1) | Closed. | 2023-08-16 14:20:02.347
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2023-08-16 14:20:08.575
The message log has been sent to support. | 2023-08-16 14:20:08.575 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 0 | 2023-08-16 14:20:08.577
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2023-08-16 14:20:08.577
The Message Log was sent. Result: Message Log received. | 2023-08-16 14:20:23.594 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2023-08-16 14:20:23.832
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:20:23.832
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-08-16 14:20:24.004
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-08-16 14:20:24.005
Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443 | 2023-08-16 14:20:32.121
DTC Client socket (1) | Creating socket. | 2023-08-16 14:20:32.129
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-16 14:20:32.129
DTC Client socket (1) | Connecting to IP: 142.215.17.189. | 2023-08-16 14:20:32.129
Denali Data Feed | Network connection to server complete. | 2023-08-16 14:20:32.363
Denali Data Feed | Starting socket receive thread. | 2023-08-16 14:20:32.363
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-16 14:20:32.364
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-16 14:20:32.597
Denali Data Feed | Sending logon request message. | 2023-08-16 14:20:32.597
Denali Data Feed | Received logon response. | 2023-08-16 14:20:33.535
Denali Data Feed | Server Name: RealTime Server. | 2023-08-16 14:20:33.535
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-16 14:20:33.535
Denali Data Feed | Failed connections: 11 | 2023-08-16 14:20:33.535
Denali Data Feed | Waiting for socket receive thread to end | 2023-08-16 14:20:33.535
DTC Client socket (1) | CloseSocket call. | 2023-08-16 14:20:33.538
Denali Data Feed | Disconnected from the server. | 2023-08-16 14:20:33.538
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-08-16 14:20:33.538
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-08-16 14:20:33.538
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-08-16 14:20:33.766
DTC Client socket (1) | Closed. | 2023-08-16 14:20:33.766
[2023-08-16 17:23:52]
The important line is the following:
You are allowed to have the Sierra Chart software running on 3 computers at the same time, but the exchanges work differently. They only allow the data to 2 different systems at the same time, and in order to do this you have to pay the exchange fees twice. Refer to the information at the following link:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
[2023-08-16 21:26:24]
Thank you, added second Denali Feed and it works now. We can close the ticket
