Date/Time: Wed, 27 Nov 2024 10:32:50 +0000
Mark a level on the fly.
View Count: 296
[2023-08-15 18:30:46] |
User731023 - Posts: 138 |
Is there any way to mark or highlight a DOM level (price) on the fly? Meaning quickly. Date Time Of Last Edit: 2023-08-16 20:53:21
[2023-08-15 21:20:30] |
John - SC Support - Posts: 36309 |
The quickest thing would be to place a horizontal line at the level where you want to make a mark. You can setup a Control Bar to have multiple configurations for the horizontal line so you could setup different colors and thicknesses for various reasons and select the control bar button then place the line. Refer to the following: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-16 20:49:43] |
Thanks. Does what I wanted/needed. In case someone reads this. It will only draw a line on a study. I am using Vbp so it will draw a line on that. I picked a horizontal line. You can see it on the snapshot. I can also drag it up and down so for my needs I only have to do it once. Draw it I mean. Date Time Of Last Edit: 2023-08-16 20:50:26
