Date/Time: Wed, 27 Nov 2024 10:45:26 +0000
[User Discussion] - Volatility Quality Zero Line
View Count: 480
[2023-08-15 15:40:24]
User38606 - Posts: 106
Does Sierra Chart have anything similar to the Volatility quality Stridsman indicator? The link below perfectly describes what I am looking for. Anything similar in custom studies?
https://stonehillforex.com/2022/11/volatility-quality-as-a-confirmation-indicator/
Thank u
[2023-08-15 16:41:15]
John - SC Support - Posts: 36309
There is nothing in that link that tells us how they are calculating this, so we can not say whether there is something similar or not.
We have set this as a "User Discussion" as hopefully someone who is familiar with the Volatility Quality can let you know.
[2023-08-16 14:29:19]
Here is the link explaining the indicator including the code. Can this be built in Sierra?
Thank you
https://www.tradingview.com/script/56Q61Aff-T3-Volatility-Quality-Index-VQI-w-DSL-Pips-Filtering-Loxx/
Date Time Of Last Edit: 2023-08-16 15:27:48
[2023-08-16 17:33:52]
We do not believe we have this natively, but it can always be programmed using our interface language - ACSIL. Refer to the information here:
Advanced Custom Study Interface and Language (ACSIL)
If you want to hire someone to do this work for you, you will find a list of programmers at the following link:
List of Third Party Sierra Chart Study and System Programmers
