Date/Time: Wed, 27 Nov 2024 12:36:37 +0000
Market Depth Historical graph showing only upto last 1 day
View Count: 300
[2023-08-15 15:07:52]
User704247 - Posts: 63
I recently switched to "US-Equities Consolidated Tape with Depth" feed and I am noticing that the market depth data (the bars) is showing only for 1 last day.
How can I resolve this?
[2023-08-15 16:17:13]
John - SC Support - Posts: 36309
Historical Market Depth Data is not yet available for the _MBO symbols. So you will only have the Market Depth for the times when you are connected to the data feed and you are storing the Market Depth data. If you have the "Market Depth Historical Graph" enabled for a chart, then the Market Depth data will automatically be saved.
Otherwise, you would want to set the Symbol Setting for "Record Market Depth Data" for the symbols for which you want to store the Market Depth Data to "Yes". Refer to the instructions here:
Global Symbol Settings: Instructions
[2023-08-15 17:22:26]
In Symbols settings, I don't see symbols with "_MBO" suffix. Do I need to add them in order to record market depth data?
[2023-08-15 21:16:09]
The best option would be to add the "Market Depth Historical Graph" to the charts for which you want to store the Market Depth. If you want to limit the display of the Market Depth Historical Graph when you do this, then set the "Maximum Levels to Display" to "1".
