Date/Time: Mon, 16 Sep 2024 19:21:11 +0000
TF chart problem
View Count: 1009
[2014-07-11 14:07:47] |
Litz - Posts: 131 |
started having problem with TF and only TF charts last nite. Time and Sales ok price shows on chart, but the candle bars are not being painted. If I delete and refresh data the bars are painted but then stop. Did not change anything and as I said the price shows on chart but no candle
[2014-07-11 16:15:23] |
We recommend disabling the True Real-time Data option: http://www.sierrachart.com/index.php?page=doc/IB.php#TrueRealTimeData After changing that setting, reconnect to the data feed by selecting File >> Disconnect and File >> Connect to Data Feed. If you still have a problem, then refer to help topic 3: http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-11 16:24:16
