Date/Time: Wed, 27 Nov 2024 10:30:42 +0000
Simulator chart replay Footprint 1 min
View Count: 342
[2023-08-15 04:14:18]
User668751 - Posts: 6
I'm using chart replay for 1 min footprint chart and isn't displaying as it should for me to do back testing on simulator am I doing something wrong. I tried scale range and changing the font size What should I do for it to display the footprint correctly so i can do the proper back testing on chart replay? I will put a video below to show you what i mean.
Private File
[2023-08-15 14:40:04]
John - SC Support - Posts: 36309
What does the data look like for that same time when you are not running a replay? It should look the same - does it not? If not, how is it different? Can you get us images of the data without a replay and during a replay?
If the data is the same, then we are not fully understanding the issue. If it is just a matter of how to best adjust the data to be able to view it, then refer to the following:
Numbers Bars: Scaling a Numbers Bars Chart
Also note the section right below the one linked above to combine data is the range is too large.
[2023-08-16 04:25:06]
It does not when I run the chart replay its like the data is super small its not looking as clean/clear as its suppose to look. I also did a comparison on my Thinkorswim back test when I typed in June 13,2023 on Chart Replay it didn't show me the accurate date 1 min footprint it was showing me July 17,2023.I will show you another video below so you can see what i mean
Private File
[2023-08-16 13:12:41]
To begin with, if you are specifying a date in the Chart Replay and it is not going back that far, then most likely you do not have the data loaded for that chart going back to where you specify the start of the replay. You would need to load more data to get back where you want to. You have to have the data loaded in the chart prior to the start of the replay.
Second, we need to see your chart scrolled back to July 17, 2023 without running a replay. We need to understand what the data looks like in this case.
If you can get us 2 screenshots it would be best. One that shows the data with the chart scrolled back and another with what the data from the same date and time looks like when running the replay.
