Date/Time: Wed, 27 Nov 2024 13:03:40 +0000
I need a little support please.
View Count: 298
[2023-08-15 01:14:24]
R&K7733 - Posts: 1
Hi, I recently sign up for a trial, but two weeks is just not enough time for me to get trade ready on this platform.
I trade every day and time is the issue. So, could you suggest to me what package I need if I only want to trade CME futures and use your Teton routing service.
I currently trade with TDA and Fidelity and both of them will remain. However, I just got approved with AMP and would probably use them as my broker on your platform.
But if you have a suggestion for a broker that is better suited for your platform by all means please advise and I will investigate.
The point is I am willing to sign up and get started with Sierra Charts, so I can have more time learning the platform. Also, for me to learn I need real time sim.
One more thing, I do not need bells and whistles when charting, I trade simple! All I need is clean, fast, accurate, trading chart with good end of the day records.
Please note I do charting on other platforms.
Thank you for your help and look forward to your response. Rick
P.S. Will any work I've done on the DEMO platform be lost if I done get to the deadline on time, as well as current login credentials?
Date Time Of Last Edit: 2023-08-15 01:26:41
[2023-08-15 13:46:58]
John - SC Support - Posts: 36309
If you do not need the Numbers Bars or TPO Profile, then you would want to be on the "Integrated Standard" package (Package 10). You need to be on one of the Integrated packages in order to connect to your broker and to be able to get the real-time data. Refer to the information here:
Description of Service Packages and Pricing: Integrated Packages
AMP is fine for a broker - it is your choice though. The list of brokers that support the Teton Order Routing Service is at Step #2 of the Setup Instructions for the Teton Order Routing Service at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
All of the information for your Sierra Chart is stored on your local system. So the first thing is to simply not remove it. Also, it does not matter what package you are one in terms of what you have on your system - so anything you have done up to this point will be there whenever you activate your new package.
Also, we do not remove accounts unless specifically asked to do so. So your account will always be available with the last password you used.
