Date/Time: Wed, 27 Nov 2024 10:46:33 +0000
Chart Header?
View Count: 459
[2023-08-14 15:48:20] |
User888495 - Posts: 3 |
-I would like to know where the setting is for my chart header in regards to "the grey box" that has Trade: 1@(market price) and DPL: Not sure how this appeared or how I can remove it?
Private File |
[2023-08-14 16:23:09] |
John - SC Support - Posts: 36309 |
When your chart has "Trade >> Chart Trade Mode On" enabled (check mark next to this option), then the "Chart Trade Mode Box" will be displayed. So the only way to completely remove it is to not have the option for "Chart Trade Mode On" enabled. One other option would be to color the background of the Chart Trade Mode Box the same as the text, so you can not see what is written, but it will give you a colored box in that area. Refer to the following item, and the one below, for the background coloring of that box: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trade Mode Box And finally, there is are two settings that will allow you to remove a couple of the items from the box. Refer to the following: Global Trade Settings Windows: Display Daily Profit/Loss On Chart/Trade DOM (Global Settings >> Chart Trade Settings >> General >> Other) Global Trade Settings Windows: Display Trade Account on Chart/Trade DOM (Global Settings >> Chart Trade Settings >> General >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
