Date/Time: Wed, 27 Nov 2024 12:25:24 +0000
weekly POC lines
View Count: 327
[2023-08-14 13:18:03] |
User285770 - Posts: 41 |
hello I did a STUDY of weekly volume value area lines I want all weekly POC lines to be on the entire chart as horizontal lines How to do it? |
weekly.png / V - Attached On 2023-08-14 13:16:35 UTC - Size: 67.84 KB - 78 views |
[2023-08-14 13:43:26] |
JohnR - User831573 - Posts: 306 |
Nice, I am creating a study that interacts with menu and mouse clicks, starting with something I created earlier. Then draws the values for the range selected. In my use case, it would provide the POC/VAH/VAH, like yours does, and then project those forward until intersected. JohnR |
[2023-08-14 15:44:48] |
John - SC Support - Posts: 36309 |
You would have to use a Spreadsheet Study and grab the information for each week and put it into its own column, which would create a horizontal line, then display those subgraphs on the chart. Refer to the following: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
