Date/Time: Mon, 25 Nov 2024 17:41:38 +0000
SMS Code Doesn't work
View Count: 416
[2023-08-14 05:12:04] |
User457712 - Posts: 1 |
Hello, When I use the code I received to activate the trial it says the code is not valid. Can you please help me solve this error? Thank you. |
[2023-08-14 13:34:32] |
Sierra_Chart Engineering - Posts: 17174 |
We have activated your Sierra Chart account.
[2023-08-14 17:13:02] |
User461523 - Posts: 1 |
[2023-08-14 19:23:20] |
John - SC Support - Posts: 36253 |
We have activated the trial for your account.
[2024-02-13 11:46:29] |
User512730 - Posts: 1 |
image_2024-02-13_184605415.png / V - Attached On 2024-02-13 11:46:07 UTC - Size: 26.89 KB - 60 views Attachment Deleted. |
[2024-02-13 17:31:22] |
User512730: You have used your trial time and we can not extend you any further. If you wish to use Sierra Chart, then you will need to pay for a package. Refer to the instructions at the following link: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-14 04:09:36] |
User764670 - Posts: 2 |
Hi my sms code not working it’s giving me error can pls activate me thanks
[2024-02-14 16:25:48] |
User764670: We see that your account is already activated. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
