Date/Time: Wed, 27 Nov 2024 13:04:58 +0000
Chart header
View Count: 428
[2023-08-13 13:00:51] |
User585104 - Posts: 142 |
Hi, So I have 2 tabs within the same chartbook. On tab 2 uncheck show title bar its fine and I can see the chart header but if I do the same on chart 1 the header is pushed up and out of view. I've tried every way imaginable to make it work but it wont. Any ideas? I have attached some pics showing you what I mean. Curiously I maximised the window and restored it and it came back as it should, but after saving and shutting down SC upon rebooting it had vanished entirely. Maximise and restore brings it back but when booting SC again it vanishes again Thanks Date Time Of Last Edit: 2023-08-13 13:20:21
Private File Private File Private File |
[2023-08-14 13:59:34] |
John - SC Support - Posts: 36309 |
Can you please get us that chartbook by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-15 13:40:04] |
We are not able to reproduce it with your chartbook. Your statement has us a bit confused - with the new chartbook are you still seeing the issue or not? This does look familiar, in that we think we have seen this previously, but we do not remember what the particular item was that caused it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-15 14:30:48] |
Yes with a clean new chartbook it does the same thing. I meant they do not contain charts with any studies or modifications
Date Time Of Last Edit: 2023-08-15 14:31:43
