Date/Time: Wed, 27 Nov 2024 12:33:55 +0000
Custom Symbol not getting historical data
View Count: 328
[2023-08-11 18:41:54] |
User480109 - Posts: 36 |
I have a custom spread symbol that I want to look into historically because both legs are expired. How do I load the historical data to see this? Currently i'm getting an FSE at the end. Attached are some screenshots
Private File |
[2023-08-14 04:19:21] |
Sierra_Chart Engineering - Posts: 17191 |
Are you able to see historical data for those symbols individually when you open charts for them? Also refer to: Custom Calculated Symbols: Resolving Missing Historical Data Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-14 04:19:32
[2023-08-14 15:44:53] |
i only have historical data for part of the period, ending in 5/30 for some reason. Is there a way to get exact dates for historical data that I need?
[2023-08-14 16:16:18] |
John - SC Support - Posts: 36309 |
Refer to the following to get additional data for the individual symbols: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
