Date/Time: Wed, 27 Nov 2024 12:27:26 +0000
Uncheck "Safe Mode"
View Count: 318
[2023-08-11 15:40:22]
User627756 - Posts: 8
Hello, I would like to uncheck the "Safe Mode" option during the login control. But when I do "exit" and relaunch using the shortcut on my system, I directly access Sierra Chart without triggering the login prompt and therefore without being able to access the possibility of unchecking "Safe Mode". How could I solve the problem?
[2023-08-11 17:42:26]
Sierra_Chart Engineering - Posts: 17191
There is always the login prompt:
Maybe you are not seeing it. It should show up somewhere on your system.
[2023-08-11 17:52:35]
Ok, now i unchecked "Safe Mode"; but i still have "No studies authorized" in "Third Party Studies Enabled For Account".
I'm not sure I fully understand the documentation for installing a customized indicator in the form of a .dll file.
[2023-08-11 18:49:59]
John - SC Support - Posts: 36309
What exactly is your question with regards to a custom indicator?
Did you create one yourself? If so, did you use our remote compiler?
Do you have a custom indicator from someone else? Did you put the .dll file in the Data folder under your main Sierra Chart installation?
Do you need help with how to actually access the study? for this, refer to the following:
How to Use an Advanced Custom Study or a Study Collection: How to Use an Advanced Custom Study Provided To You
[2023-08-11 21:33:05]
It's a custom indicator from someone else.
I don't understand how to put the .dll file in the data folder from documentation.
[2023-08-12 15:03:37]
Put the DLL file in the C:\SierraChart\Data folder on your system.
Then start with step 5 here:
