Date/Time: Wed, 27 Nov 2024 13:04:58 +0000
Liquidité
View Count: 291
[2023-08-11 15:04:51]
SASU PEDI ME MOCHET - Posts: 3
Bonjour,
J’aimerais savoir si la somme de liquidité acheteur et vendeurs en dessous du prix et au dessus du prix peut être écrit à côté du prix de l’instant.
Si oui
Quelle est la démarche
Cordialement
Edouard mochet
[2023-08-11 15:08:55]
John - SC Support - Posts: 36309
From Google Translate:
I would like to know if the sum of liquidity buying and selling below the price and above the price can be written next to the price at the moment.
If yes
What is the process
You would need to use two copies of the "Bid and Ask Depth Bars" where the Input for "Mode" is set to "Sum Bid Side" in one and "Sum Ask Side" in the other. You can hide these studies if you do not need to see them.
Then use the "Text Display for Study" to display the "Close" of each of the Bid and Ask Depth Bars, one will be the sum of the Bids and the other the sum of the Asks. Please the text display where you want it.
Refer to the following:
Bid & Ask Depth Bars
Text Display For Study
