Date/Time: Wed, 27 Nov 2024 12:28:09 +0000
Re: Reminder - Sierra Chart: Payment Notification- NO Marketdepth !
View Count: 265
[2023-08-11 14:42:06]
ShuvFlowTrader - Posts: 30
Hi, I have observed another problem recently while trading the MES(as a trade symbol) with ES as the marketdata. The problem is, when I have a simultaneous 'Buy Exit' and 'Sell Entry' condition triggered, and let's say I have zero 0 prior position, the short trade is Not opened.
I have 'Allow entry with working orders' turned to Yes.
I would expect to have the new position initiated. Similar behavior on 'Sell Exit' and 'Buy Entry' too.
Any advice ?
[2023-08-11 14:54:40]
John - SC Support - Posts: 36309
If you are using the Spreadsheet System for Trading?
We just tried this with the Spreadsheet System for Trading and we are not seeing the issue you state. When we have both a Buy Exit and a Sell Entry at the same time, the Sell Entry is properly entered and the Buy Exit is ignored.
The one item that we needed to ensure was done was setting the Input for "Reset Condition on New Bar" to "Yes", but this was not due to having both Buy Exit and Sell Entry set, it was about how had the conditions setup, which were just an entry of "1". But it makes us wonder if you may need this same option set to "Yes" for the way your conditions are setup?
