Date/Time: Mon, 16 Sep 2024 19:15:00 +0000
Trade Order Error - AMP/TTnet
View Count: 1889
[2014-07-11 08:46:15] |
AC95501 - Posts: 28 |
Hello SC-Team, I tried to place a buy stop-limit order within Sierra Charts with AMP/TTnet, but the following message appeared in the Log and the order was not send. Trade Order Error - TT order update (Rejected). Info: EX: INVALID COMBINATION OF ORDER ATTRIBUTES, NO VALID ORDER PROFILE FOUND. Internal Order ID: 13496. Service Order ID: 0238JN305. Symbol: FGBL-201409-Eurex | 2014-07-11 10:41:10 Can you help me there? Are there any open positions now? Best regards Max EDIT: If I'm right, there are no stop-limit orders allowed on EUREX. I turned this off and place only stops. Date Time Of Last Edit: 2014-07-11 08:56:50
[2014-07-11 09:19:26] |
If you are getting an error submitting an order, then definitely the order has been rejected and you should not be concerned about a position being established. This is an error message from the TT FIX server: Info: EX: INVALID COMBINATION OF ORDER ATTRIBUTES, NO VALID ORDER PROFILE FOUND. It could be that Stop-Limit orders are not accepted on the EUREX. You need to check with EUREX about this. Is a Stop Market order working? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-11 09:19:52
[2014-07-11 09:21:45] |
Ok, that's great. So I don't have to worry about any open orders that I can't see. Stop Market Orders work so far. |
[2014-07-11 10:11:22] |
OK good.
[2014-07-11 12:27:57] |
User021827 - Posts: 174 |
I have had multiple problems with eurex on amp/TTnet all week. Still cannot get data without errors. I would not trade eurex until AMP can confirm that this has been fixed. |
