Date/Time: Wed, 27 Nov 2024 12:23:20 +0000
Is there a way to make profiles number 1 and 2 overlap?
View Count: 259
[2023-08-11 08:38:17] |
natngk - Posts: 16 |
These are one-period based 2-bar count profiles. I want to make them overlap like the visible bar profiles on the right-hand side.
CleanShot 2566-08-11 at 14.44.34.png / V - Attached On 2023-08-11 08:34:29 UTC - Size: 80.76 KB - 67 views |
[2023-08-11 13:18:55] |
John - SC Support - Posts: 36309 |
You either have the profiles overlapping on the far right or they are separate. There is not a way to have 2 separate profiles that are overlaid. Refer to the following input that controls whether a profile is separate or drawn to the farthest right: Volume By Price Study: Allow Side-By-Side Profiles on Right Side What exactly are the two profiles you are wanting to overlay? For the visible bars you state are overlaid, did you set the Input for "Allow Side By Side Profiles on Right Side" to "No"? Or is this something different? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
