Date/Time: Wed, 27 Nov 2024 12:38:21 +0000
Where to Change Angle Based Gradient Color?
View Count: 264
[2023-08-11 03:17:53] |
User429065 - Posts: 118 |
Where can I change this from white to grey? I'm not finding it anywhere, thank you!
[2023-08-11 12:52:55] |
John - SC Support - Posts: 36309 |
There is not a way to set the "secondary" color for the angle based gradient. It is just using lighter shades of the specified color. You can set the Angle Unit as negative to change the way the coloring is done. Refer to the following: Chart Studies: Angle Based Gradient For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
