Date/Time: Wed, 27 Nov 2024 12:34:41 +0000
identifying child orders attached to parent
View Count: 301
[2023-08-10 23:30:09]
User879924 - Posts: 50
Hi SC,
Is there a way to give each individual limit order and its associated bracket a different color, name or number?
When I have a couple of limit orders set (as show in the screen shot) it is very difficult to know which associated child orders are attached to which parent order. Is there a way to make it clearer?
It would be super helpful if say the 1st limit order and it's bracket could be green and the second be red or something like that.
Thanks for your help.
imageScreenshot 2023-08-11 at 9.25.55 AM.png / V - Attached On 2023-08-10 23:29:41 UTC - Size: 18.15 KB - 73 views
[2023-08-11 12:45:32]
John - SC Support - Posts: 36309
There is not an option for coloring, but there is the "Order Association Lines" that you can turn on to connect the specific items together. Refer to the following:
Global Trade Settings Windows: Order Association Lines (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display)
