Date/Time: Wed, 27 Nov 2024 12:29:52 +0000
data missing in ES charts
View Count: 261
[2023-08-10 17:25:02] |
User423974 - Posts: 18 |
Kindly note there is a missing piece of data on ESU23 TPO, quarterly, monthly and weekly charts between 14th and 24th of july 23, software is on 2457. It happened as I was on july 14th loaded the data with the new subscription, and the next login was on 24th , and this missing piece was not loaded, even with everyday's reload of data. Iam on service package 11 with denali data feed. P.S this happens regularly with ES only Date Time Of Last Edit: 2023-08-10 17:28:20
[2023-08-10 17:36:57] |
John - SC Support - Posts: 36309 |
To fill in any missing data, follow the instructions at the following link: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) You really should not have this issue. Next time it happens, please get us your Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
