Date/Time: Fri, 18 Sep 2026 15:52:28 +0000
Color the bar chart
View Count: 1451
[2014-07-11 02:34:02]
User17064 - Posts: 70
Hi SC support,
Is there any possible method to color the bar chart? My thinking is if the close of the current bar is lower than the close of previous bar, then current bar should be colored as red bar. Vice versa, if higher than should be green. Is there any way to do that?
Thanks!
[2014-07-11 03:05:20]
Yes. This can be done through the color settings in Global Settings >> Graphics Settings.
You also need to enable Global Settings >> Graphics Settings >> Other >> Up/Down Coloring for OHLC Bars Based on Previous and Current Close.
[2014-07-11 05:01:02]
Thanks for quick reply.
One suggestion: if SC could let the close of the bar with the same color with the bar chart body, it will be perfect. Now is only one default color
[2014-07-11 05:27:04]
You may want to use Global Settings >> Graphics Settings >> Other >> Color Entire OHLC Bar the High/Low Color.
[2014-07-11 09:25:10]
thanks a lot!SC support are so kindness and now what we thought.
