Date/Time: Wed, 27 Nov 2024 13:03:31 +0000
Lowest Volume in A Bar connect with a line bar to bar
View Count: 345
[2023-08-10 13:28:16]
Oz - Posts: 50
What's the easiest way to plot the lowest volume in a bar and have these connected with a line, bar to bar.
Thank you,
[2023-08-10 14:11:12]
John - SC Support - Posts: 36309
You can use the Numbers Bars study and highlight the Minimum Value in column 1. Then use the "Study Subgraph Reference" to reference the "Price at Minimum Highlight" subgraph from the Numbers bars study.
Note that if there are multiple values for the highlight in a bar, the value at the highest price is the one that is stored in the subgraph.
Also, when we tried this to ensure that it worked, for some reason the data in the subgraph only went back about 20 bars. We do not know why this is.
To be able to get more data and get to a particular level, you would have to create a custom study and sift through the volume data per bar to find the level you want. Refer to the following:
ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar
