Date/Time: Tue, 26 Nov 2024 08:53:27 +0000
How to hide a spreadsheet
View Count: 281
[2023-08-09 13:49:41] |
Federico Roveda - Posts: 34 |
I would like to hide a spreadsheet (*.scss) that I use to calculate some stuff, is there a way like for the single charts with Window>Hide Window? Thanks
[2023-08-09 14:47:40] |
John - SC Support - Posts: 36286 |
There is not a way to hide a Spreadsheet window. The best you could do would be to "Detach" the Spreadsheet from the main Sierra Chart and then minimize it to the Task Bar. Refer to the following: Detaching and Attaching Chart Windows: Detaching a Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-11 15:15:51] |
User835583 - Posts: 16 |
I understand that hiding this window does not exist currently. Is there anyway we could request this feature to be added in future updates. I would like to have this option as well! Thanks in advance. |
